V6 Unplugged!!!
V6 Unplugged!!!
I am in the process of stripping the interior due to a shed load of water on the passenger side footwell...caused by the smallest of holes on the floor it would seem.
Anyway, opened the bonnet to disconnect the battery (don't want the tensioners going off in my face) and i found a plug...that wasn't plugged in!
Can anyone identify this for me? It's in the top right corner of the engine bay, to the right of the fuse box, and has about 7 multi-coloured wires going into it.
Thought i should ask before i plug it in and cause any probs.
By the way...how sensitive are the tensioners? I have to take the seats out to get the carpet out, and i'm getting nervous :icon_pale
JesterV6
dunno mate, always had it plugged in, plug it in and if the engine management light comes on when you start it then you may find out why its been unplugged, or maybe someone forgot to plug it back in when it was plugged into a diagnostic machine
have a look here and it tells you all about the plug and how to read codes etc
<a href="http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm</a>
sorry haven't gotta clue on the seats issues, never done it before
Cozy
