AFM Sensor on V6
AFM Sensor on V6
I have just noticed that there is some kind of sensor infront of my AFM on the V6?????
Does anyone know what this is for as I have just took it off to fit an air filter and have just left it by the side o the filter :0
simonV6
Definitely put it back.
Yes you can theoretically trick the ECU into injecting more fuel because it thinks the air is colder than it is BUT the V6 ECU will compensate for the over fuelling using the reading from lambda sensor and cut back the fuel injection cycle. End result is a poor running V6 with no benefit gained.
hoglabs
