more fault codes
more fault codes
by ikledud » Sun May 27, 2007 11:01 am
well ive just had the cally throw a load more fault codes at me 145 wich is something to do with the imobiliser but i have had a clifford fitted wich replaced all that?? 21 throttle position sensor high voltage and 45 oxygen sensor where is the best place to buy all these from cause i know vaux are gunna want me to take out a morgage to buy the o2 sensor, and is the imobiliser fault cause there isnt an imobiliser there any more lol and is it a prob?
ikledud
by ikledud » Sun May 27, 2007 11:31 am
also is it throwing 45 (air fuel mixture to rich) because its retarded my timeing cause of the other faults?
ikledud
by Phantom » Sun May 27, 2007 5:13 pm
firstly are you reading the codes with the engine running?
Phantom
by leegte » Sun May 27, 2007 5:17 pm
i think he must be or else hed have the crank shaft sensor code
what running problems/symptoms do you have
leegte
by ikledud » Sun May 27, 2007 6:09 pm
well i did it with engine running and not running but i knew about the crank sensor no signal so didnt put it up here lol well i reset my ecu and the only code im getting now is 17 knock sensor 2 wich i ripped my arms to peices changing yesterday!!!!!!!! looks like its the sledge hammer for the cally
ikledud
