Dicky indicator
Dicky indicator
by Animal » Mon Oct 16, 2006 7:07 pm
My indicator switch has a fault where every so often it only takes a faction of pressure forward to flash the high beam. Anyone else had it??
Is the switch servicable?
by EY » Mon Oct 16, 2006 10:51 pm
Yeah mine started doing this. Bit of a pain as you come up the sliproad onto a motorway, start to indicate, and full beam everyone as you join. I took the indicator unit to bits and found that one of the little copper connectors was a little bit bent. It took hours, as it f-ing fiddley. Seriously....don't bother trying to fix it, it's soooo much easier to fit a whole new indicator unit. [img]/smile.gif[/img]
by Animal » Fri Oct 27, 2006 11:51 pm
How much is a new one from vauxhall?
I'll probably get one from the scrappers.
I wasn't sure if my 100w high beam could have fried it. I think they are on a relay though.
by Robs-se » Sat Oct 28, 2006 11:42 am
i've seen these on ebay
by Tim2001 » Sat Oct 28, 2006 12:08 pm
Scrapyard will be the best bet 10 mins max to remove
Tim2001
by Animal » Sat Oct 28, 2006 2:26 pm
Are they the same unit on a vectra?
by Animal » Sun Oct 29, 2006 1:33 pm
Just looked in the wanted bit. Noticed someone else had the same problem too.
So that's three people at least with the same problem.
by JesterV6 » Fri Nov 03, 2006 4:52 pm
Had the same problem, posted it a about a week or 2 ago under "My Calibras New Game" or something like that. Fixed mine yesterday. Got an indicator stalk delivered from a scrappy off a Cav, simple to remove and replace. Only prob i have now is that there were 2 wires lodged into the copper connectors...worked out one was to flash my indicators when i alarm the car, not sure what the other one was, so just trimmed them back and left them [img]/biggrin.gif[/img]
JesterV6
by Animal » Sat Nov 04, 2006 2:35 am
I fixed it too.
Got a spare one from the scrappy incase I screwed mine up (bit shabby compared to mine).
Cracked mine open tidied inside up straightened a bent pin. Stuck it back together. Voila!
One thing to watch out for is it springing apart when you take the top off!
by scotte84 » Sat Jan 19, 2008 5:38 pm
Thanks for that info guys, i also have that same fault, ill be going to a scrappy tho, other option doesnt sound like so much fun. Thanks again.
scotte84
by Phantom » Sat Jan 19, 2008 6:38 pm
I replaced mine with a new one from e-bay cost me £15
Phantom
