Indicator Relay keeps blowing
Help pse my previous post was why I heard a noise from fuse box no indicators....changed relay all works fine for about a day then goes again...£9 a time, dont know if related but drivers side back & front are very dim..thanks..
andym1fjg
Sounds like a bad eath, check the holders and the contacts and give them a bit of a clean up.
Tnx for info shall check it tmoz,I gotto admit something else thou...b4 all would be fine for a little while then would blow fuses, well i didnt have a 10a at that time so stuck just a slightly larger fuse in...so maybe the current trying to blow a fuse dont now so takes it out on the flasher unit ..anyway the main thin gotta get to the root of prob so will check contacts etc..tnx for infos...
andym1fjg
Users browsing this forum: Bing [Bot] and 33 guests
