Fuel pump problems.
Fuel pump problems.
Hi people,
I have a problem with the wifes '91 8v.
It was left standing for a while and when i tried to start her she fired but died, it would appear that the fuel pump isn't working.
Is this a common thing after being left standing and the battery going flat?
Any help would be gratefuly recieved.
wcorkcalibra
no not a common problem for the pump to die, but there is a common problem with the fuel pump relay.
you can identify if that is the cause because the ECU light shoudl come on when you first put the ignition on before trying to crank, if it doesnt, then its because of the relay.
welcome to the site
welcome to the site
Ref codes, read here
http://www.topbuzz1.carenthusiasts.co.u ... .htm#bosch
Users browsing this forum: Bing [Bot] and 32 guests
