Yellow Plug For Fuel Comp
was to whoever is trying to find the yellow plug
if you check under the small removable plastic bit under the handbrake you will see a larger white multi plug
on the drivers side there should be a bunch of wire to wards the front of the car, with a spare bit at the rear for the FC switch to plug into,,,if not then unlikely there is a yellow plug to find
