blowers not good
Re: blowers not good
Allys Cally wrote:had this with mine before, check the pollen filter there's a good chance it either full of crap or it's saturated with water
i had a poke about & the filter looks almost black, found a couple of leaves on top of it & a few small stones on top. plus i noticed the wiper arms have damaged some of the filter too, is that normal?
frankej
if it's black then it's F****d, take it out and try your blowers
Allys Cally wrote:if it's black then it's F*****d, take it out and try your blowers
can the filter come out without removing the wipers & plastic thing?
frankej
Yes tere is two clips at the front each side of the pollen filter housing, Just pull up the plastic thingy as you call it, undo the two clips, pull filter out
Fraz wrote:Yes tere is two clips at the front each side of the pollen filter housing, Just pull up the plastic thingy as you call it, undo the two clips, pull filter out
thanks mate, i'll give it a try
frankej
you mean you've not done it yet, hurry up man
Thanks ally, i changed the pollen filter, now blows like a force 10 gail!!!
- Attachments
- pollen filter.JPG (62.72 KiB) Viewed 8186 times
frankej
yeah, i had the same problem lad, my filter was clogged full of all kinds of s**t.
Berny
glad to help mate, always check the easy things first
