Driver's window
Driver's window
by bigdaz1987 » Thu Nov 25, 2010 7:37 pm
there seems to be something wrong with my driver's window it opens fine when door closed or open but when i go to close it with the door closed it bounce's back down but when the door open it close's fine it has never done this before anyone any idea's :think:
bigdaz1987
Re: Driver's window
by Fraz » Thu Nov 25, 2010 8:12 pm
get some silicone lubricant and give the rubbers a wipe
Re: Driver's window
by Robs-se » Thu Nov 25, 2010 9:50 pm
Mines for ever do this, just use the button and bring it up gradually
Re: Driver's window
by k1nty » Fri Nov 26, 2010 11:01 am
there is an adjuster for the inclination..mine used to do it,locknut and adjuster at bottom of door (door card off) and im sure theres a hole at rear of doors bottom?(maybe grommit in this?).also have you relearned the windows?holding the up buttons down at full travel?once i changed the battery and the windows kept going up then down a bit till i did this.
edit:im not sure if the learn feature is part of my full closure or standard?
k1nty
Re: Driver's window
by skitz_1184 » Fri Nov 26, 2010 10:16 pm
Try reseting the window. press the down button and hold it when the window is fully down for 5 secs and then close it again holding the close button for 5 secs after it closed, worked for me :)
skitz_1184
Users browsing this forum: Bing [Bot] and 6 guests
