Loving my EDS Phase1
Decided to go for the Phase1 as the engine on the LE is older (though solid) and the SE5 was an utter mentalist!
Bought the copies from mgear555 on eBay and being the second set the guy has not let me down!
Great purchase!
Sean.
Great purchase!
Sean.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Re: Loving my EDS Phase1
so what power are you getting?
Sorry for the delay,
250 is the quoted amount and removal of 1st gear limiter. I havent pushed it to the top of the rev range but it should be higher. It was just a small but sensible mod. Didn't want to pull her apart. The last engine was designed for stupid amounts of power and it handled it very well.
Sean.
Sean.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
se5 wrote:Decided to go for the Phase1 as the engine on the LE is older (though solid) and the SE5 was an utter mentalist!
Great purchase!
Sean.
I've always had bad experience with buying copies off eBay (ie they never work and the ECU light is always on).
Are you saying these don't have the ECU light on?
Did you set it up on a rolling road afterwards (ie did you have to adjust the boost via the actuator)?
Also what ECU type do you have, PJ, PK or HD?
Alan Knight (Topbuzz)
W: www.topbuzz.co.uk
E: webmaster@topbuzz.co.uk
