4x4 light
fault code 31
by pauldarcy » Fri Jun 18, 2004 2:53 pm
my cally turbo intermittently has the 4x4 light illuminated. it only happens on starting but remains until i next start up with a break.it doesn't always do it . can anyone give me some pointers?
pauldarcy
by Kieran_Burns » Fri Jun 18, 2004 3:16 pm
You're not starting with your foot on the brake pedal are you?
Do you hear a 'clunk' noise when braking?
Kieran_Burns
by skellem » Fri Jun 18, 2004 3:18 pm
If you start the car with your foot on the brake pedal it will stay on.
It sounds like you need to get your transferr box seen to. Not really a job you can do yourself unless you have a lot of patience! Speak to the chaps at VTS for some advice about the box.
skellem
by pauldarcy » Sat Jun 19, 2004 5:28 am
i have probably been starting up withmy foot on the brake. is this a bad thing and to be avoided?
pauldarcy
by Kieran_Burns » Sat Jun 19, 2004 10:12 am
It is if you want to run with 4 wheel drive... just don't put your foot on the brake when starting...
I always dip the clutch myself - takes the transmission offline so it's easier to start and stops the worry about leaving the car in gear.
Kieran_Burns
by pauldarcy » Mon Aug 30, 2004 9:39 am
problem is down to 4x4 solenoid valve switch. 700 hundred quid retail from v/hall......arse!but managed to get secondhand one off a 8v 4x4 for £40 [same part] hurray!!!!!!!!!!!!
pauldarcy
by skellem » Mon Aug 30, 2004 9:52 am
Excellent mate! I'm sure you are relieved!
skellem
Locked posts
by Smurf » Mon Aug 30, 2004 10:36 am
8v 4x4??! Doesn't exist!! I guess you mean the 16v 4x4?
Well done on getting it sorted at such a good price mate!
Smurf
by Stupink » Mon Aug 30, 2004 6:36 pm
Cavalier 8v4x4 would be my guess... but yes i dont think they ever did the calibra version..
by pauldarcy » Tue Aug 31, 2004 11:33 pm
sorry ,yes its a cav 8v but the important thinis they are the same!also cause only a numpty sits behind the wheel of one they are likely to have no idea what price to sell such bits and haven't a clue what they are!!!!!!
pauldarcy
