Glove box light and cigarette lighter back light.
by Phil » Wed Feb 18, 2004 2:02 pm
Hi folks. Am finally here sussing out the new forum.
Can anyone help? Some time in the past I butched my cigarette lighter power feed to add neons. I didn't like them and so removed them!
Now my glovebox light and cigarette lighter back light don't work. The bulbs are fine. I find the glovebox one really handy so any ideas what it could be? I checked the related fuse in the fusebox, that was fine too.
HELP.
Thanks.
Phil
by Col_UK » Wed Feb 18, 2004 7:11 pm
have u actually checked to see if there's power going to em?
Col_UK
by Cally-boy » Wed Feb 18, 2004 7:34 pm
Sounds like your feed has a break in it. Carry out a check to see if there is a power feed to it.
Cally-boy
by Phil » Thu Feb 19, 2004 12:10 pm
Guessing it is a power feed issue. Where to check for the break?
Everything seems to run from each other!!
Phil
by Dave_GTi » Thu Feb 19, 2004 12:54 pm
You should be able to pull out the ashtray and test the 2 connectors on the back of the fag lighter, using a multimeter (or similar).
Dave_GTi
by Phil » Mon Feb 23, 2004 11:24 am
Thing is the fag lighter works fine. I though the lights for the lighter and the glove box used at least part of the same feed? :?
Phil
by brocklanders25 » Mon Feb 23, 2004 3:23 pm
hmm i've got a similar problem mate, i hi-jacked the cigarette lighter for my amp (don't ask) the lighter still works fine but it doesn't light up and the glove box one doesn't work either its got me stumped! i can only think the extra current has melted or broken the illumination loom somewhere
i'm like you though..i want everything to work or i get annoyed :x
brocklanders25
by Phil » Tue Feb 24, 2004 10:55 am
Sounds like the same as me then. I hi jacked it for neons.
Well, the first to solve the problem has to post it here! PLEASE??!
Phil
by Phil » Tue Feb 24, 2004 11:00 am
Huh? I posted a new topic and it arrived here?!!!
Phil
Users browsing this forum: Bing [Bot] and 111 guests
