Lights
RE: Regional Register
well I fitted mine and the barke warning light works just fine. As does a few others that have them fitted. Could it be you have a faulty brake light bulb?
RE: Immaculate calibra turbo and parts
Well they both work mate, I'm puzzled!!!!!!!!!!
RE: Is it too much?
seem to remember someone had same probem, IIRC was something to do with the bulbs , changed them for new ones and it cured the problem
just a thought...you dont have a third brake light? (on a spoiler or in the back window)
Swap the bulbs mate. My old volvo turbo had the same thing. Turns out it measures the difference in voltage between the two bulbs and not if one is out. If one bulb is a different make or has been bashed about a bit it could see a difference in voltage between the two although they still work. Grab two new ones from halfords and give it a shot. Failing that make sure all yer earths are tight. Should be a relatively simple thing to fix.
Good luck
Bigun.
Good luck
Bigun.
bigun
RE: no rca plugs on head unit
Not led bulbs are they? If so you will either have to fit a resister,Or take the warning bulb out.
Fostersice17
fuel computer, fuel sensor calibration.
Did you put the silvertech bulbs in or just coloured indicators mate?
Mac
RE: Another broken sunroof
Problem fixed. New bulbs all round. Jobs a good'un.
Cheers guys.
Cheers guys.
