what the heck is this light for???
Good old map point!
by tb303 » Mon Jan 17, 2005 6:51 pm
i was driving back from work today. it was raining. i had this light on after a 20 minutes run and wouldnt go off. i parked after 10 minutes and switched the car off. I started the car again and stepped on the brakes and the light went off. after 2-3 minutes it came back on. what is it for? is it something realy important? does it have to do something with the breaks? how do i find out what is the problem and fix it please?
cheers
tio
tb303
RE: Good old map point!
by Fraz » Mon Jan 17, 2005 6:58 pm
its a brake bulb failure warning light, should light up when you first start the car and go out when you press the brakes
Looks like you have a faulty brake light bulb
by tb303 » Mon Jan 17, 2005 7:09 pm
all bulbs are ok. none burned. and the damn thing won't go off till i switch off the car.
tb303
RE: what the heck is this light for???
by c1emm » Mon Jan 17, 2005 7:13 pm
A Fraz said [img]/smile.gif[/img]
its nothing major just means you have a bulb out somewhere
c1emm
RE: Re: RE: Body Panels
by ROG » Mon Jan 17, 2005 7:27 pm
My k reg does this when its raining its water getting into the back light, on the bulbs, i think the car picks up the resistance changing and thinks the bulbs gone.
ROG
by tb303 » Mon Jan 17, 2005 7:38 pm
could it be brake fluid level?
it's the one in the red box.
tb303
ABS Light
by Stupink » Mon Jan 17, 2005 8:20 pm
As said about 3 times already its the brake light warning bulb. If the bulb isn't gone, then its a dodgy connection most likely..
I do believe i heard somewhere one of the bulbts is linked somehow to the brake fluid level yeh, but if that level is ok then its going to be dodgy connection on the brakelight bulbs porbably, forget if they look burnt or not.. while the light is on the dash do both brakelights work? I have a feeling the fluid level thing is the ABS light not the light we're on about. i cant remember.
by Robert_Dale » Mon Jan 17, 2005 8:44 pm
brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb brake light warning bulb
CHECK YOUR BULBS HEHEHEHE:) but also mate yeh it does pick up a different resistance and comes on in the rain
Robert_Dale
RE: This years PV2k5, time guestimate quiz! (std. bored post
by c1emm » Tue Jan 18, 2005 12:18 am
i take it was a brake light warning bulb then rob [img]/biggrin.gif[/img]
c1emm
by Robert_Dale » Tue Jan 18, 2005 11:45 am
<!--QuoteBegin-c1emm+--><div class='quotetop'>(c1emm)</div><div class='quotemain'><!--QuoteEBegin-->i take it was a brake light warning bulb then rob [img]/biggrin.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
LOL what makes you say that [img]/biggrin.gif[/img]
Robert_Dale
by c1emm » Tue Jan 18, 2005 5:35 pm
just a rough guess [img]/biggrin.gif[/img] think u may have mentioned it some where along the lines [img]/biggrin.gif[/img]
c1emm
A Re-Spray??? (How much should it cost/did you pay?)
by BazV6er » Tue Jan 18, 2005 5:54 pm
probably a very dirty connection in the cluster
