alarm not workin
by projectcalibra » Sun May 21, 2006 7:28 pm
cheers. taken 5 weeks tho :oops: ok, now thats sorted, the last problem i have with this side of it, the locks r shocking, sometimes they central lock, other times they dont, sometime the alarm arms, sometimes it doesnt. any way of gettin remote locking to work with standard alarm?
projectcalibra
by RobbieV » Sun May 21, 2006 7:30 pm
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->cheers. taken 5 weeks tho :oops: ok, now thats sorted, the last problem i have with this side of it, the locks r shocking, sometimes they central lock, other times they dont, sometime the alarm arms, sometimes it doesnt. any way of gettin remote locking to work with standard alarm?<!--QuoteEnd--></div><!--QuoteEEnd-->
You could try this
<a href="http://www.clubcalibra.net/forum/articles.php?action=viewarticle&artid=19" target="_blank">http://www.clubcalibra.net/forum/articles....rticle&artid=19</a>
[img]/smile.gif[/img]
by projectcalibra » Tue Jun 06, 2006 12:38 am
ok not fixed as some nice young chap or chapette felt the need to break in and steal all my stuff, need help on gettin this fixed. can some one please give me a step by step guide on what to look for and where. pics are helpful because im not good at finding things
projectcalibra
by projectcalibra » Tue Jun 06, 2006 7:33 pm
ok fault is 13 'Oxygen Sensor' wats this and how do i fix it
projectcalibra
by Leigh » Tue Jun 06, 2006 11:54 pm
Oxygen sensor (a.k.a. Lambda sensor ) is the thing you can see bolted into the manifold/downpipe if you look at the pipework just below the engine, should have a wire coming off it, it measures (apologies for the less than precise description) the amount of oxygen in the exhaust gases so the ECU knows how the engine is running.
Fairly easy to spot on the 8V with the engine bay having a lot of space.
Nothing to do with the alarm tho mate, sounds like you were/are reading out the ECU codes, not the alarm codes (or at least looking them up on a list of ECU codes)
Leigh
by projectcalibra » Wed Jun 07, 2006 6:10 pm
yeh my bad. got code 3,4 but cant find what that means. the bonnet sensor works, but the boot, doors and motion sensors dont appear to set the alarm off
projectcalibra
by projectcalibra » Wed Jun 07, 2006 6:16 pm
also, when i lock the door, the light comes on for about 5secs, then goes out and does not flash there after, then on unlocking it does the same, comes on for about 5secs and then goes out. is this normal?
projectcalibra
by steviemac » Wed Jun 07, 2006 9:51 pm
Have you checked the door lock mechanism on the inside. Part of mine had broke of and because of it my alarm wouldn`t work.
steviemac
by projectcalibra » Wed Jun 07, 2006 9:54 pm
no aint checked that, what am i looking for, does the door work on a similar principle to the boot? also what does the red light coming on for 5 secs then going off mean
projectcalibra
by MR_TOAD » Sun Jun 11, 2006 9:18 pm
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->ok not fixed as some nice young chap or chapette felt the need to break in and steal all my stuff, need help on gettin this fixed. can some one please give me a step by step guide on what to look for and where. pics are helpful because im not good at finding things<!--QuoteEnd--></div><!--QuoteEEnd-->
atfer all money spent on diagnostics
Cheaper to but Toad Alarm that will do more than you have now
Ian
MR_TOAD
Users browsing this forum: Bing [Bot] and 15 guests
