what seems to be wrong with my interior light
pretty bright mate , look here mate:
http://www.freewebs.com/baz16v/modificationsspecs.htm
i did find out what caused this and it was all down to the alternator at xmas
the leds ive got are designed to run at 4.3 volts so they need to be used with a resistor to work they have a 35 degree viewing angle but in comparrison to a normal bulb they are blinding you are right about current but as long as the resistor is in series and not paralell to leds the change in voltage should not affect the led's
turbonut
