Battery Wires Help!
by hormonedmonkey » Thu Mar 06, 2008 7:35 pm
well, i've put it to the negative and the other 2 to the positive.
working fine, except ABS light has come on!????
hormonedmonkey
by hormonedmonkey » Sun Mar 09, 2008 4:46 pm
Can this have effected the ABS light???
How can I sort?
hormonedmonkey
by RobbieV » Sun Mar 09, 2008 7:03 pm
by hormonedmonkey » Sun Mar 09, 2008 7:28 pm
There are no fault codes.
hormonedmonkey
by RobbieV » Sun Mar 09, 2008 7:32 pm
Take wheels off and clean the ABS rings and sensors.
by hormonedmonkey » Sun Mar 09, 2008 7:48 pm
Can someone show me where these are?
hormonedmonkey
by Phantom » Mon Mar 10, 2008 3:26 pm
the ABS ring is behind the hub, look for a toothed wheel, best way to clean this will be to rotate the hub and clean with a wire brush, the ABS sensor is near to the ring aprrox in the 2 o'clock position looks like a plasic thing with a peg sticking out of it, may need to remove this to clean it or again just clean with wire brush
by hormonedmonkey » Mon Mar 10, 2008 5:52 pm
Thanks Phantom
hormonedmonkey
