Yellow Plug For Fuel Comp
by vinny_69 » Wed Oct 08, 2008 6:11 pm
if the question was for me fraz yep and me got one 8)
if not sorry
vinny_69
by Fraz » Wed Oct 08, 2008 6:46 pm
was to whoever is trying to find the yellow plug
if you check under the small removable plastic bit under the handbrake you will see a larger white multi plug
on the drivers side there should be a bunch of wire to wards the front of the car, with a spare bit at the rear for the FC switch to plug into,,,if not then unlikely there is a yellow plug to find
by eco16v » Wed Oct 08, 2008 6:51 pm
found the yellow plug after removing most of the centre console,it was jammed tight between the side of the dash and the heater controls, thats y i couldnt see it.
eco16v
