Knock sensor wire
Re: Knock sensor wire
which one is it and ill go back down and take another
knock sensor....you should know where they are
no only one ..its not a V6
i cant get a good pic of it but it plugs into the black plastic bit the carries the rest of the look right in between the head and inlet hope that makes sense and helps
FOUND IT!!!!!!!!!!!!!!!!!!
its on the underside of the black plastic wire carrier.
ste_goffy
ste_goffy wrote:FOUND IT!!!!!!!!!!!!!!!!!!
didnt I say that
