Trip computer into an SE8?
Re: Trip computer into an SE8?
If your car is not wired for a fuel computer
You will need a connector.
Connect up the following wires to wires of the same colour:
Red to clock connector red +12v power
Black to clock connector black ignition
Browns to clock connector brown ground
Grey/black to instrument connector illumination
Blue/black to instrument connector fuel tank sendor
If you are replacing a digital clock/temp display you can connect up the following wires dirrectly to its old plug
Blue Temperature
Blue/White Temperature
Blue/Red Speed
Grey/black Illumination
Otherwise :
The Blue and Blue/White wires need to be run under the bonnet to the temperate sensor
The Blue/Red wires should be connected to the wire of the same colour at the radio, instruments or ecu connector (see below)
Locate the 3 square connectors under the engine ecu. Connect up the wires there of the same colour.
Red/White
Black/Brown
And the switches in the center console :
Switch common switch connector 6 brown/yellow
Reset switch switch connector 4 brown/white Convex rear
Hours switch switch connector 3 brown/blue Right
Mode switch switch connector 2 brown/red Concave front
Minute switch switch connector 1 brown/black Left
You should be left with a brown/white wire and a brown/red wire used for diagnostic’s
Blue Temperature
Blue/Red Speed
Otherwise :
Red/White
Black/Brown
Thanks Fraz that will come in handy when I wire the switch in, save me having to use wiring diagrams. PM sent big_gordy.
oh thank a Mr Andu Kirwans for that info
vinny_69 wrote:oh my bad i thought it was like for like
thats why things go bang when you do electrics
Allys Cally wrote:vinny_69 wrote:oh my bad i thought it was like for like
he usally brings it up to me mate and i make it go bang for him
tazz666
well u could do a how to then vinny
lol
lol
Allys Cally wrote:thats why things go bang when you do electrics
Yep
tazz666 wrote:he usally brings it up to me mate and i make it go bang for him![]()
don't tell porky's mate your a magician in my eyes
but i wont be up on the 4th mate but i will see you for Dunnys fix a banger day on the 17th big_gordy wrote:well u could do a how to then vinny
vinny_69
