Dash lights
Re: Dash lights
I have a new one mate if you need it £15.00 . First have a look at the cable about 20 - 30cm back from the sensor. If it has wire crimps then check them first. I noticed the weather had got in and had corroded the crimps. I solderd on the new plug and cable that you get with the sensor and tried that first and it worked and its still working 5 years later.
Re: Dash lights
When I check it tomorrow Phil I'll let you know ,cheers
Re: Dash lights
Done the 25 times on and off with the ignition and its cleared
the fault. Thats a handy tip,thanks boys
Re: Dash lights
that cleared the airbag light as well? and do you mean the ecu fault light is off now ...or you have checked and the code is cleared
Re: Dash lights
The ecu light is now off but the air bag light is still on
Any ideas how to get this off?
Re: Dash lights
youll need to get it turned off with a computer
Re: Dash lights
craigyboy wrote:are you the man for the job Steve?
i dont have the laptop youll need to speak to Mr T
Re: Dash lights
sounds like a plan.I'll have to get it fixed as I hate driving with
warning lights on the dash.My near side back light keeps coming
on and off and the warning light comes on the dash.Is there a multi
plug somewhere behind the dash? I think its just a connection making
and breaking.Any ideas?
Re: Dash lights
mine does that Craig all i need to do is take the build out and push the connection bits with a screw driver my only problem i need to remove 1/2 an install to get to it
Re: Dash lights
Ive tried all that.its definetly a break in the supply from behind
the dash somewhere.It only started since we had the ECU out
