for all you electronically minded people
by Naz » Fri Apr 08, 2005 11:42 am
Hello
I need help. I have a mini DV camcorder which uses 2AA batteries. The problem is that it uses lots and lots of battery, 2 brand new batteries will only last about 15-30min.
So what i wanna do is to make a small power supply so that i can connect it to my car battery.
The car battery is 12v and when charging you get around 14v, so to step this down to 6v DC, would i just put a 6v regulator before the camera or do i need any filteration circuit as well?!!!
I know 6v regulators are rated to around 30v, which means anything up to 30v they can reduce to 6v and above that i take it as they blow?!!
Cheers for the help
Naz
by Rusty_CallyT » Fri Apr 08, 2005 11:47 am
gonna need a heatsink on the reg as it will get really hot dropping 12/14v to 6v but it should work
Rusty_CallyT
by icewizard » Fri Apr 08, 2005 12:47 pm
If if takes 2 x AA batteries then should it not run off 3V?
Unless it has a DC socket that takes 6V
if it kills batteries in 30 mins then it's prob drawing over 1 Amp.
So you're gonna need a decent regulator that can handle that current.
Does the DV Camcorder display how much Current or power it uses?
icewizard
by Naz » Fri Apr 08, 2005 12:56 pm
lol
YOu are absolutely right! my math think went out the door!
So yeah i will need a 3v regulator. I can't find any specs on the camcroder itself. Bought it about a yr ago, will look on the web to see if i can find any specs.
THe problem is that it has LCD display and i think thats what kills the bloody bateries.
I can measure the current by a multimiter i guess
Naz
by Chavtastic » Sun Apr 10, 2005 9:50 am
Why not just get an 240v invertor for the cig lighter in your car... then run the camcorder off the house charger plug you have?
by sofaman » Sun Apr 10, 2005 11:05 am
I'm not very good with electronics, I basically know how a circuit works. But if you can run off 2 X AA then could you modify one of these to give you better amps??
<a href="http://www.maplin.co.uk/Module.aspx?ModuleNo=37423&TabID=1&source=15&WorldID=&doy=10m4" target="_blank">http://www.maplin.co.uk/Module.aspx?Module...rldID=&doy=10m4</a>
prob not much help but may give u another idea [img]/smile.gif[/img]
sofaman
by Stupink » Sun Apr 10, 2005 11:10 am
Not such a bad idea, naz arnt you running the vhs off an inverter anyway? the extra current from the power adaptor will still be well within any of the basic inverters capabilities [img]/smile.gif[/img]
by Naz » Sun Apr 10, 2005 9:14 pm
Well no Stu, The VHS is a incar one, it already has a 12v input for it, the screen is also 12v. Thats why i bought them, so i wouldn't need a inverter.
In my work van i have some DC to DC converters, i think they regulate 12v to 5v for out use. One of them could be faulty, if you know what i mean [img]/wink.gif[/img]. Will have a look and see what i have in the van.
Naz
by davamb » Mon Apr 11, 2005 9:17 am
You want 3V as Stu says. Best bet is to use an LM317-ADJ voltage regulator, setting the programming resistor values for 3V. Let me know if you need help with that. A heatsink would be wise also.
davamb
by Naz » Mon Apr 11, 2005 4:57 pm
Hi Dave
Been looking at the RS website and can't find that component on theirs. Do you know of any online places i can download info on that?!!
Naz
