Clearing Fault Codes?
by Rust » Mon Apr 18, 2005 12:50 pm
I have a 16v ecotec Calibra & I am trying to clear the fault codes from the ECU. According to the FCR & the Haynes Fault Finder Manual all you have to do to clear the memory is to disconnect the battery for 5 mins or take out the ECU fuse (I presume the correct fuse is one of the fuses in the fuse box in the engine bay) for a few seconds. Neither of these two options has cleared the Fault Code memory.
Anyone out there know what I am doing wrong.
Cheers,
Rusty.
Rust
by sofaman » Mon Apr 18, 2005 12:59 pm
you can only clear the fault codes if you have eliminated the faults
try this thread
<a href="http://www.clubcalibra.net/forum/showthread.php?t=10784" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=10784</a>
I'm guessing here but if u have the same ECU as me then u need to turn the ignition on for 5 seconds then back off. Do this 30 times to clear it. But it all depends on which ECU you have. Or goto vauxhall and pay them to to it [img]/sad.gif[/img]
hope this help
sofaman
by Fraz » Mon Apr 18, 2005 3:32 pm
ALso that dont work with the ectotec ...some you can clear the faults by turning the igntion on and off for IIRC 30 times
only real sure way though is a Tech1 at the dealers
by Rust » Tue Apr 19, 2005 12:15 pm
Thanks for replys, useful links.
Thanks,
Rusty.
Rust
