Wierd dash display
ARgg.. the electrics in that car sound almost as bad as mine.. heh..
Hate electrics..
Just get a multimeter and check the voltages across the battery, engine off/idle/2k and with load on it.
If that shows ok, then just go through all the earth straps and connections to make sure they're ok [img]/sad.gif[/img]
Hate electrics..
Have you had the clocks out at all Dan? Sounds like it could be just one of the multi plugs on the back of the dash not quite in correctly. Failing that check all of the earths in the engine bay in case one has work it's way slightly loose. Also check the battery terminals for security (you never know).
SteveU
The electrics on this car are really bad. When you start the car in the morning and accelearate too quickly before the engine is warm the alarm starts sounding and doors lock :0)
The clocks were taken out by the previous owner as he has put blue leds in the dash
Thanks for the advise guys I will take a look at the weekend.
cheers
cheers
DAN
Users browsing this forum: No registered users and 112 guests
