Whats this?
Whats this?
Whats this connector do? does it plug into the socket on the washer bottle? it appears to have some wire poked in the end and is taped over.
Any ideas?
Any ideas?
Rusty_CallyT
the sender does pull out, I ran out of water the other day and my light wasn't on. did come on but for only the intial check. So I took out the sensor. Look like it just a magnet on a float. cleaned and tested it and now my fulid light is on perm [img]/sad.gif[/img] will have a look another day. So yes the sensor just pulls out, just make sure the water level is below the hole !!!
sofaman
