Total closure windows......?????
by jimbohotpants » Tue May 24, 2005 12:17 am
Its like this..... My cally is supposed to have total closure of its windows when the key is turned 45degrees and held there for 2 seconds or so.
This doesn't happen on mine.
I have tried resetting the windows' programming.
The driver's side doesn't have a microswitch. The passenger side does. Neither side will give any closure with this method.
I have tried grounding the Brwon/Black wire in the driver's footwell to the chassis.... no joy.
Can anyone help me? Do I need the driver's microswitch for either side to work? Is there a more serious problem?
Any help would be much appreciated!
jimbohotpants
by jimbohotpants » Wed May 25, 2005 1:50 pm
Can nobody help me!!???!!
jimbohotpants
by Rusty_CallyT » Wed May 25, 2005 2:00 pm
how long did you ground it for? did it lock the doors?
Rusty_CallyT
by BazV6er » Wed May 25, 2005 2:07 pm
ive tried mine a few times it works but sometimes you turn the key to 45 degres and the locks lock
by Rusty_CallyT » Wed May 25, 2005 2:12 pm
thats the point mate, you turn it to 45 degrees the doors lock u wait there and the windows go up but you have to hold it there untill they are right up
Rusty_CallyT
by jimbohotpants » Wed May 25, 2005 2:50 pm
When I turn it 45 degrees, the locks lock. I hold it there forever, but no window movement, either on the passenger side or driver's.
I held a connecting wire from the terminal of the Brown/black wire behind the fuse tray in the driver's footwell (which went into what looks like a relay, together with a thicker black wire), to the body of the car for about 20 seconds or so. I tried quite a few times in case I wasn't getting a decent contact, but to no avail!
From what I gather, each window motor has its own timing circuit inside, so if I ground the circuit at any stage (like the microswitch would do), then they should just operate. Am I mistaken? Can someone set me straight please?
jimbohotpants
by jimbohotpants » Thu Jun 02, 2005 11:28 pm
You'll be pleased to know that I've sorted the problem now! All it needed was the microswitch![img]/smile.gif[/img] I've rigged it to the alarm now too so the windows go up with remote locking![img]/smile.gif[/img] Luvly jubbly!
Cheers for all the help guys!
jimbohotpants
by Rusty_CallyT » Fri Jun 03, 2005 12:18 am
nice one mate [img]/biggrin.gif[/img] i love the remote closure on mine its great... to show off! [img]/tongue.gif[/img] [img]/laugh.gif[/img]
Rusty_CallyT
by jimbohotpants » Fri Jun 03, 2005 10:30 am
It is indeed!! [img]/wink.gif[/img] Now I just need to get the sunroof involved! Needs a bit of thought I reckon.
jimbohotpants
