Can a sub flatten my battery
by Murdomac » Tue Mar 16, 2004 9:54 pm
Have been haveing issues with my battery going flat if I leave the car sitting for 2-3 days. I recently installed a new uprated battery and a sub box/amplifier (I had no problems before this), could the sub be somehow draining the battery? What could I test/look for.
Murdomac
by Col_UK » Wed Mar 17, 2004 12:44 am
check the wiring isn't shorting to earth somewhere
remove power lead to the amp for a few days see if the problem occurs again as it coud be the fact the battery is no good
do u use the stereo a lot when the engine isn't running?
have you checked the charge going to the battery?
Col_UK
by DAN » Wed Mar 17, 2004 5:47 pm
Do you have it wired correctly. ie does the sub switch off when you switch the car off? Make sure you have connected the remote lead to the ignition live and not the permanent live
cheers
DAN
by Murdomac » Wed Mar 17, 2004 6:32 pm
Ok.. The wireing is def not shorting to earth, I don't use the stereo when the engine isn't running, the volt meter in the car says its charging at 14v, the sub goes off when the head unit goes off, the remote lead I have conected to the head unit.
I will try disconecting it for a few days to see what happens.
Murdomac
by SteveU » Wed Mar 17, 2004 9:49 pm
Sound like a weak battery to me (unless you're boot light's staying on or summat else daft like that).
SteveU
Users browsing this forum: Bing [Bot] and 94 guests
