LEDS in headlight switch
by jeffp » Mon Jul 04, 2005 11:20 pm
Iam in the process of fitting LEDS to my switches etc, so far i have done the heater control, rear de-mister switch,headlight adjuster switch, and both fog light switches,my problem is with the headlight on off switch,i have fitted the LED but it comes on with the ignition is this right ? ,i dont seem to remember it being on before with the normal bulb though of course it could have blown.Also i have looked on the german site and it shows +ive as the left connection and -ve as the right (or centre one if you count the unsoldered one) i tried this and it didnt work so i swapped them over, +ive on the right , -ve on the left.A word of caution to anyone attempting this mod make sure you dont remove the spindle the knob fixes to, as two small bearings and a spring launch themselves across the room, and if you can find them they are an absolute arse to get back in.To avoid this after removing the switch from the car refit the knob before taking the back of the switch.
jeffp
by sofaman » Mon Jul 04, 2005 11:45 pm
you have done it right mate, it comes on with the ignition so u can see the switch in the dark [img]/biggrin.gif[/img]
Thats a nice word of caution about the springs [img]/biggrin.gif[/img]
got any pics of your heater control ??
sofaman
by jeffp » Mon Jul 04, 2005 11:56 pm
cheers sofaman ill be able to sleep now,got the leccy window switches and the heated seat switches to do then ill try and get some pics,thanks again
jeffp
by zerocool » Sun Jul 17, 2005 4:30 pm
Any diagrams anywhere or explanations on how to fit all the leds as i would like to have a go.
zerocool
by Monkey » Sun Jul 17, 2005 4:34 pm
Look at Simons (Daddycool) site <a href="http://www.turbocalibra.co.uk" target="_blank">www.turbocalibra.co.uk</a> or <a href="http://www.blauertacho.de/doc/opel/cal/index.htm" target="_blank">http://www.blauertacho.de/doc/opel/cal/index.htm</a>, both of these will help you very well.
Monkey
by daddycool » Sun Jul 17, 2005 5:17 pm
<a href="http://homepage.ntlworld.com/swmorris/blue_leds.htm" target="_blank">http://homepage.ntlworld.com/swmorris/blue_leds.htm</a>
daddycool
Users browsing this forum: Bing [Bot] and 33 guests
