question time..........
hi guys anyone has any ideeas why my track control light(t.c) stays on?
blue_v6
errrr because it could be broken???
If it doesn't go out when you press the switch, then there is a fault with the TC system.
Try taking it for a drive and see if you can get it to wheelspin......
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
If it's the same as mine was, TC light come on when you switch ignition on, then goes out after a couple of seconds. But as soon as you start to move the light is back on and stays on, i'd go for dirty / knackered T.C. motor.
Mine was, i followed a 'how to clean your T.C. motor' on 'cavweb' which had pics 'n' all. Took me about 2 1/2 hours, it's not given me any more trouble and works a treat now.
//Andy
//Andy
Andy SE9 V6
Mmmm..my traction control light decides itself weather or not its coming on!..sometimes it does and sometimes it doesn't!..has a mind of its own..usually comes on as i reverse off the drive and if i stop and restart the engine it'll stay off for days before deciding it's had enough, and comes back on!
SE9
