Central locking dicky!
by lammy » Fri Jul 29, 2005 1:12 am
My central locking is playing up and on occasions doesn't work on the drivers door..the passanger door has to be locked for it to kick in!..is there an easy fix?
SE9
by sofaman » Fri Jul 29, 2005 1:50 am
if you lock the car with the key and not by remote. Then it's most likely your door lock.
Remove the door card, loosen the window rail. undo the lock and take it to a local lock smith who will charge u £10 - £15 to repair it.
There should be 2 switches connected to your lock, check they fitted ok
HTH
sofa
sofaman
by lammy » Fri Jul 29, 2005 2:04 am
Thank for the quick reply...Cheers i'll have a look at it.
SE9
Users browsing this forum: Bing [Bot] and 34 guests
