cooling fan
cooling fan
can anyone tell me the best way to wire my cooling fan up to a switch,so it all done right
cockney16v
1. It should be right as it is as the cooling fan should come in when the temperature rises. If this is not happening then you need to check the sensor on the side of the radiator.
2. If you really want it controlled by a switch that I would not reccomend then take the two wires from the temp sensor and add a switch in these wires.
Tim2001
