URGENT - help-please - no power to the dash
by niggy0 » Wed Aug 31, 2005 8:42 pm
Just fit a new fuel pump relay to the car - But when I put my key in the ignition the car will start - but no dash board lights will come on nor will the speedo, rev counter, oil temp or fuel gauge function.
The voltage gauge, oil pressure and stereo dont work either
However the dash illumination does with the lights on, as does the center console back lights (heater fan etc) these are on constantly when the key is in the ignition - without the lights on........ the battery is lit up when the car is running as well
Did take the battery off when I changed the Ecu a couple of weeks ago - but have not ran the car since then (due to fuel pump relay)
It is the correct ecu and the correct fuel pump relay (both from Vx)
can any one help ......please.....................
niggy0
by niggy0 » Wed Aug 31, 2005 8:44 pm
niggy0
by Fraz » Wed Aug 31, 2005 9:03 pm
sounds like you have a blown fuse
by niggy0 » Wed Aug 31, 2005 9:20 pm
The stereo's dead - but the heater blows - cold for definate not tried hot air tho.
niggy0
by niggy0 » Wed Aug 31, 2005 9:22 pm
any idea what fuses it could be - have had a quick look in the fuse box n they all looked fine (admitedly it was dark)
niggy0
by niggy0 » Wed Aug 31, 2005 9:23 pm
Yeah but which one - thay all looked fine when i had a look with my torch ( its a bit dark out there)
niggy0
by Cheater2k » Thu Sep 01, 2005 10:21 am
Top left - 2nd fuse in, 20 amp
Cheater2k
