Alarm - windows roll up
by Cheater2k » Wed Sep 14, 2005 10:24 am
Right then, M reg calibra.
Unlocks and lock, also windows roll up
Now, on my old calibra (N reg) i could just shut the windows and not lock the doors, now when i press button 4 to roll the windows up, it locks as well, any ideas?
(Toad AI606)
Cheater2k
by jimbohotpants » Wed Sep 14, 2005 2:18 pm
Was it the same alarm set-up? Otherwise it sounds like the alarm's got a lock feed and a separate pull-down to ground (for the windows) that fire at the same time. You'd have to check the alarm fitter's manual probably to find out if you can separate the two feeds to two buttons.
Does what I just said make sense? I dunno.
jimbohotpants
by Cheater2k » Wed Sep 14, 2005 2:28 pm
its the same alarm (ai606)
im just wondering if theres a different wire in the passanger footwell for window roll up, not both.
there is for lock and unlock.
Cheater2k
by icewizard » Wed Sep 14, 2005 7:14 pm
Find the central locking relay that's located in the drivers footwell, then cut the Brown/White wire. That will stop the doors locking when the windows are auto closed.
The doors will still lock when you arm the alarm, that wire is just for locking by using the key in the door that's all.
icewizard
by Cheater2k » Thu Sep 15, 2005 1:21 am
no probs as the lock is coming out of the door anyway, being delocked.
Cheater2k
Users browsing this forum: Bing [Bot] and 7 guests
