Ignition Switch/Alarm
by Chew » Tue Sep 27, 2005 9:10 am
I have just recently bought myself a Calibra Turbo, however i have a few slight niggling problems, one of which is my ignition
When i turn the key off, sometimes the engine carries on running, but even if it cuts out all the ignition lights stay on. For this reason, i am having to take the battery off every night.
Has anyone had this problem?
I thought about just getting a new ignition switch, but if say the fan i running and i turn the key off, the fan goes off, however all the ignition check lights stay on on the instrument panel
Any help would be much appreciated
Chew
by Cheater2k » Tue Sep 27, 2005 9:29 pm
sounds like somones wired a perm live to a switched live somwhere.
Cheater2k
by ealex » Wed Sep 28, 2005 12:13 am
most likely the cd player is wired wrong, especially if its fuse has been changed to a higher rating
ealex
by Cheater2k » Wed Sep 28, 2005 12:17 am
aye, like a crossed wire [img]/smile.gif[/img] (perm / switch live)
Cheater2k
by Chew » Wed Sep 28, 2005 7:49 am
There is currently no stereo in the car
Forgot to say it does Have a Clifford G4 Alarm on it with remote window close. Could thie be causing the problem?
Chew
by Chew » Thu Sep 29, 2005 1:11 am
Got the problem sorted, some wires were shorting under the bonnet - £30
Chew
