Mannix 2 Way Pager Alarm
Missionmasque
<!--QuoteBegin-nariman1977+--><div class='quotetop'>(nariman1977)</div><div class='quotemain'><!--QuoteEBegin-->you get two function assigned buttons. YOu can assign whatver you want to them. But the window closure doesn't work automatically.
Cheers<!--QuoteEnd--></div><!--QuoteEEnd-->
Did you fit it yourself ?
If so, is there any tips other than it's going to take all day
Missionmasque
<!--QuoteBegin-nariman1977+--><div class='quotetop'>(nariman1977)</div><div class='quotemain'><!--QuoteEBegin-->yes, i did fit it myself. Yes it does take all day as i had to take off lots of stuff to do it nice and neatly.
It ain't hard, just follow the instructions. Have haines manual in front of you with the wiring diagrams as you need to know the color of the wires in the cally.
Thanks for that.
I'm expecting delivery on Wednesday and probably going to do it the following weekend.
Thanks for that.
Missionmasque
<!--QuoteBegin-GeordieSteve+--><div class='quotetop'>(GeordieSteve)</div><div class='quotemain'><!--QuoteEBegin-->If I get one fitted professionally will it be Thatcham rated???<!--QuoteEnd--></div><!--QuoteEEnd-->
No, the Alarm is not Thatcham rated.
They say on there web site that they are applying for the rating this year.
If you fit yourself you lose the 1 year warrenty.
Missionmasque
