Side repeaters
Side repeaters
by cchapman191 » Tue Oct 18, 2005 11:36 pm
Hi all
My drivers side repeater has given up ghost, just isn't working. Can anyone tell me where I can find the other end of the wire as I want to check it is in or on properly ?
Thanks
Craig
cchapman191
by splinter » Tue Oct 18, 2005 11:39 pm
Hi, I would first make shore the bulb hasnt blown.. !!!!!!!!!!
Before you go down that road.
by cchapman191 » Tue Oct 18, 2005 11:48 pm
sorry splinter I forgot to mention that it is LED
cchapman191
by splinter » Tue Oct 18, 2005 11:51 pm
Right then.... [img]/smile.gif[/img]
Have they got water in them... ??? have you looked ????
If not then do so.
If its not working the leds might of gone bang.. dont happen alot.. !!!!
Or the wire you put on to them has come undone ???
by cchapman191 » Wed Oct 19, 2005 12:02 am
Okay defo hasn't got water in because the one on there is brand new !
Checked the lead and not sure of the LEDs
I suppose I could try again, could be crapcheapness from ebayy !
Where can I get a decent set of led side repeaters ??
Thanks Splinter
cchapman191
by cchapman191 » Fri Oct 21, 2005 1:25 pm
anyone ? or where can I find it in the haynes manual ?
Craig
cchapman191
by Mong0L » Fri Oct 21, 2005 1:30 pm
could you not swap the repeaters from side to side to see if the non working one, works?
Mong0L
by trev150 » Mon Oct 24, 2005 5:45 pm
Did it use to work?
Or is it wired up the wrong way around?
by cchapman191 » Tue Oct 25, 2005 12:21 pm
It did use to work but for some reason I have got 2 lots of side repeaters brand new and none of them seem to be working on the drivers side.
I will try to get the passenger side off and test it but I was hoping to follow the wiring back to the main point but cannot seem to find where that is.
Criag
cchapman191
by trev150 » Tue Oct 25, 2005 9:09 pm
Have you checked it with a multimeter?
by cchapman191 » Wed Oct 26, 2005 1:45 pm
no I haven't as I don't have one but I shall try !
cchapman191
by trev150 » Wed Oct 26, 2005 9:13 pm
Use a headlamp bulb and connect it to where the side repeaters go, it should light up.
Users browsing this forum: Bing [Bot] and 27 guests
