Window Closure
Window Closure
Do all calibras come with automatic window closure? I just got one of those total closure systems from Jimbohotpants and was wondering if it's even worth it.
Because I was informed after the purchase that it doesn't control the windows, just the sunroof!
I have no way of testin the key lock method, since my calibra's been de-locked.
If it's not standard on early calibras, is it possible to install it?
King Calibra
<!--QuoteBegin-ealex+--><div class='quotetop'>(ealex)</div><div class='quotemain'><!--QuoteEBegin-->all the callys i ever seen had auto window closure. though it doesnt work perfectly<!--QuoteEnd--></div><!--QuoteEEnd-->
On models without remote keyless entry, where is the actuator for the window closure? My car has an alarm installed that controls the central locking, but not the windows. is there a way to change that?
King Calibra
Ive got a 'cobra' system on my car...And it only pulls the drivers window up...Doesnt do the passenger side...
its rather annoying actually, having to unlock the car, touch the little thingy on my keyring to the dash, and then turn the key...Especially when you turn the engine off, you have to re-do the whole thing!!! lock, unlock, wait for red light, touch the thingy with the other 'thing' then turn the key!!
a_c
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Because I was informed after the purchase that it doesn't control the windows, just the sunroof!<!--QuoteEnd--></div><!--QuoteEEnd-->
I thought I made it very clear that it only does the sunroof mate! If you're not happy, send it back and I'll give a full refund.
jimbohotpants
<!--QuoteBegin-jimbohotpants+--><div class='quotetop'>(jimbohotpants)</div><div class='quotemain'><!--QuoteEBegin-->I thought I made it very clear that it only does the sunroof mate! If you're not happy, send it back and I'll give a full refund.<!--QuoteEnd--></div><!--QuoteEEnd-->
Maybe just a misunderstanding.
Don't care tho. I WILL get the blasted thing to get my windows to close too [img]/laugh.gif[/img] I just wasn't sure if early reg calibras had the window closure at all.
Figured the best way to find out would be to pop a thread into the forum.
I'm not unhappy, just doing some research before I start chopping up wires. [img]/laugh.gif[/img]
King Calibra
<!--QuoteBegin-MR_TOAD+--><div class='quotetop'>(MR_TOAD)</div><div class='quotemain'><!--QuoteEBegin-->Brown Black wire add a negative feed to this wire it will close windows
can be found coming out of both front doors
It will not close sunroof as this is a seperate unit
Ian<!--QuoteEnd--></div><!--QuoteEEnd-->
So, as a test, if I were to ground that wire out to the chassis, it would close the windows?
King Calibra
Users browsing this forum: Bing [Bot] and 25 guests
