is this easy to wire up?
by chamby » Thu Oct 27, 2005 6:54 pm
well
im very tempted to buy some leather heated seats and the oil/volt gauge but i dont know if it would be easy to wire them in?
does anybody know if they are kinda plug n play like the trip computer or is it hard to do or even imposible?
i drive a '92 16valve calibra with standad seats and jus the little shelf where the oil/volt gauge would go
any help would be greatly appreciated
chamby
by jayl645 » Thu Oct 27, 2005 6:57 pm
seats are just plug and play,will wire up easy,not sure on the gauges tho.
jay
jayl645
by King Calibra » Thu Oct 27, 2005 6:59 pm
Last time I checked theres a little tiny shelf under the ash tray that the little switch console for the heated seats goes, and the harness for it should be in there somewhere.
King Calibra
by jayl645 » Thu Oct 27, 2005 7:28 pm
to get them working u need to buy the switches and surround(i got mine off ebay for a 10er).king calibras right,the switches go in the little space u have under the ash tray and hold in with 1 screw.
the wires are behind the ashtray quite fiddly to get but well worth it,
jay
jayl645
by chamby » Thu Oct 27, 2005 7:45 pm
so is the wireing for the seats themselves under the carpets ou is it under the side trim? and is it easy to find?
chamby
by jayl645 » Thu Oct 27, 2005 8:09 pm
mine was just under the carpet,very easy to find,better to look for it when the seats are out,
4 bolts hold the seats in.
jay
jayl645
by cally228 » Thu Oct 27, 2005 8:19 pm
Just remember to secure your seat belt restrainer first.
by ross85 » Thu Oct 27, 2005 10:40 pm
I'm putting my gauges in sometime soon hopefully, had them over 6 months lol. If you haven't got the plug/loom for the gauges you can get something similar from a PC store or website for a couple of quid. There's only four wires to connect up, one goes to the oil pressure sensor which you screw in near the oil pump, then one goes to ground, and two go to +ve, one for lighting and one for the voltage gauge. You can pinch the three wires from the headunit or from the cigar lighter, whichever you fancy
ross85
by ross85 » Thu Oct 27, 2005 10:41 pm
sorry just realised its a 16 valve, think you screw the oil sender into the block somewhere. Pretty sure there's a guide kicking around on the net for putting the gauges into a C20XE but can't remember where! :roll:
ross85
by chamby » Fri Oct 28, 2005 10:11 pm
does anybody know where i can find this guide? done a search n come up with thousads of articles but none r the correct 1
chamby
