interior light question......
by BazV6er » Tue Nov 08, 2005 1:17 am
is there anyway i could get my interior light to come on when i arm/disarm my alarm ?
by LewJamBen » Tue Nov 08, 2005 1:29 am
My mums Astra does this so I asked my mechanic/electrical whizz friend if its possible to make the calibra do that. In a word no!
LewJamBen
by ealex » Tue Nov 08, 2005 8:05 am
with relays it is possible
ealex
by BazV6er » Tue Nov 08, 2005 12:00 pm
so what relays do you have to get to do this?
by Fraz » Tue Nov 08, 2005 3:11 pm
well the Interior light has a permanent 12V feed, the switch on the door pillar supplies the earth connection .....so if you can get a earth supply coming from your alarm module for say 30 seconds ..it should work
if your wanting the interior light to stay on till the ignition key is turned then you would need to get some sort of relay to supply a permanent earth feed to the light , and when it gets an ignition live cut the earth connection .
don't ask me which relays though ..leave that to the clever ones
by BazV6er » Tue Nov 08, 2005 3:39 pm
cheers fraz
by Smurf » Tue Nov 08, 2005 7:50 pm
Both my Calibra's have done this, so I assumed it was normal?!
When the system is unarmed, the interior light comes on. Arming it again won't switch the interior light off straight away, it'll go off on it's standard delay.
Smurf
by King Calibra » Tue Nov 08, 2005 11:28 pm
On the later models yes, just like the later models have the interior light that fades out.
King Calibra
by BazV6er » Wed Nov 09, 2005 11:16 am
i think i will have to locate my alarm module first and go from there....
by daddycool » Wed Nov 09, 2005 8:04 pm
Locking and unlocking the door on mine switches the light on and off (after the delay).
As arming and dissarming the alarm locks and unlocks the doors, it also controls the light [img]/smile.gif[/img]
daddycool
