help needed from cally experts
by btom » Mon Nov 14, 2005 12:39 pm
i been tryin to get my cally running like new for a while now and with the end in sight i got two lights on the dash that should not be there my brakes are fine and oil is ok how do i get the lights off i dont care if they dont work as i check oil and brakes regular so any idea will do . brett
btom
by Cozy » Mon Nov 14, 2005 12:40 pm
remove the bulbs from the dash???
Cozy
by SukySaggi » Mon Nov 14, 2005 12:58 pm
<!--QuoteBegin-Cozy+--><div class='quotetop'>(Cozy)</div><div class='quotemain'><!--QuoteEBegin-->remove the bulbs from the dash???<!--QuoteEnd--></div><!--QuoteEEnd-->
No:no:
Brakes - Get yourself some new brake sensors. About £20 from Vauxhall or disconect your current ones.
Oil - Probably the oil level sensor. Try removing the old one and cleaning it out or a try a good oil flush. Vauxhall will be expensive to change (parts).
SukySaggi
by j4mes » Mon Nov 14, 2005 2:03 pm
as suky says.
j4mes
cheers gents
by btom » Tue Nov 15, 2005 3:05 pm
ill disconnect the buggers then do u know how i get to the oil sensor
btom
by SukySaggi » Wed Nov 16, 2005 4:05 pm
The oil level sensor is just screwed into the sump. On the turbo its at the front. Be carefull though you will lose a bit of oil when you remove it.
SukySaggi
by FatLadZ » Wed Nov 16, 2005 6:29 pm
Right the experts here [img]/biggrin.gif[/img]
The brake sensors can be unplugged and shorted out in the wheelarch so that the bulb goes out from the pad wear sensor.
The oil pressure sensor wire has either corroded or broke somewhere along the way.
The oil sensor wire is easily accessable from under the car and it sits below the alternator.
Or it could be the oil level wire and that sits at the front of the sump and runs up the front of the gearbox.
Just check the wiring before disconnecting anything [img]/smile.gif[/img]
fatz
FatLadZ
