radiator fan
radiator fan
im gonna be quick. my radiator fan does not start, temp slowly rises and holds between the two red lines. i couldnt find its fuse anywhere. although it is listed on the cover of the fusebox, there is no fuse connector in that position. i have no idea what to check first. i dont wanna go buy a new one and then find out its a fuse or its thermostat.
ealex
faulty wiring and a burnt jack on the fan made it go to heaven. put in new fan, and problem solved. kind of. i need to change the termostat relay on the radiator also, cus it only starts the low stage. however, if u short the wires of the thermostat it starts at maximum rpm. will have to wait for part to arrive on monday
ealex
