Two white clocks
Two white clocks
Does any one know if i got hold of the oil and volts clocks wth no wires how easy it would be to fit them .thanks
hardcorecally
I bought some off ebay ages ago and finally fitted them last week. Try and get the connector plug with a bit of loom, if not you can buy something similar from PC World which is what I did. There's only 4 wires to connect up, one to the oil sender, one +ve one -ve and an illumination feed so they light up with the dash/clock. The wires can be taken from the clock, cd player or cigar lighter, it's up to you really.
Wiring picture <a href="http://www.cavweb-forums.co.uk/showthread.php?t=107" target="_blank">here</a>
Oil sender <a href="http://www.autovaux.co.uk/StockItem.asp?AVCode=AVEL&AVNo=111&cat=20&carID=57" target="_blank">here</a>
ross85
VDO gauges for V6
Does a 94 V6 Calibra have the wiring plug loom etc for the centre consule oil and volt gauges?
mdav1970
