VDO gauges
VDO gauges
Does any one now if a 94 V6 Calibra have the wiring plug loom etc for the centre consule oil and volt gauges?
mdav1970
no you will need to tapp into the radio or clock for the volt and you will need a oil pressure sender you will also need to go to a pc shop as they sell a lead with the correct pin connector its like a cdrom cable hope this helps if you need a wiring diagram i have one handy i will email it if you require cheers will
wilza0
