Toad Ai606 LED
Toad Ai606 LED
Righty then after I wired it myself and everything was fine a few days later the LED stopped working properly and is now on permanent green, Is the LED Brock or something else
rob
<!--QuoteBegin-Welsh_Andy+--><div class='quotetop'>(Welsh_Andy)</div><div class='quotemain'><!--QuoteEBegin-->permament green is unarmed iirc when i press button(unlock) it goes to green,but only for 30secs then bk to red,can you still lock the car with the remote? if yes does it still stay green, are you getting 2 bleeps when armed/unarmed<!--QuoteEnd--></div><!--QuoteEEnd-->
sounds about right to me, think your immobilser is not working, leave the window and set the alarm after 30 secs stick you hand in and see if internals sensors are working.
Like andy said how many bleeps do you get when setting the alarm?? any more than 1 and you have a fault.
You may of put it in valet mode,but with the toad it's not easy to do, lots of flashing light counting and key twisting,
Will
Will
WillsToy
<!--QuoteBegin-WillsToy+--><div class='quotetop'>(WillsToy)</div><div class='quotemain'><!--QuoteEBegin-->sounds about right to me, think your immobiliser is not working, leave the window and set the alarm after 30 secs stick you hand in and see if internals sensors are working.
Like Andy said how many bleeps do you get when setting the alarm?? any more than 1 and you have a fault.
Will<!--QuoteEnd--></div><!--QuoteEEnd-->
Alarm is ok as I get 1 beep on arm and 2 of disarm and also immobiliser as well like when I leave it unarmed for a bit it kicks in and it wont start.
I dont have internals sensors just a brake glass sensor.
rob
