Windows
Windows
<!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto--><!--coloro:red--><span style="color:red"><!--/coloro-->my passenger one is fine but when i go to shut the drivers side it get about an inch from shutting then decides to go half way back down, makes me look a bit of a t**t when i walk away push the remote central locking and watch the window play up [img]/smile.gif[/img] <!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc-->
turbo83
Try opening the door and reprogramming it (hold the button 5secs after window down fully, then 5secs after window up fully.
I like to use halfrauds silicon spray lubricant to keep the rubbers a bit moist to aid water proofing, it helps them slide better too, that might be second, else you're going to have to look at ajusting the angle of the window as its still pressing too hard against the side rubber and probably needs leaning out a bit more. (end of the door bottom little rubber hole with 10mm bolt in there, slacken, move window tighten.
turbo83
