Help needed. no headlights, no speedo light no nothin'!
by hormonedmonkey » Mon Jan 23, 2006 11:57 am
Any help much appreciated. Just bought another Calibra. Been fine until the 2nd day, typical, eh!?
The headlights only work if I push the headlight unit in and hold it there squeezed a bit. Is any1 following???
and also my speedo light has gone out and on the other side none of the heater panel lights are working, aswell as the clock light and the actual clock has stopped working.
I've checked the fuses. What can it be? Could it be that the whole headlight panel that holds the switch, headlight adjustor, fog light switches needs changing? If i hold the panel in the headlights work fine, aswell as the fog switches, but the lights on the adjustor and headlight switch don't light up.
I'm confussled.
hormonedmonkey
by hormonedmonkey » Mon Jan 23, 2006 12:03 pm
could it be loose? i don't get it.
hormonedmonkey
by Fraz » Mon Jan 23, 2006 1:17 pm
there is a big multi plug at the back of the headlight switch, and two smaller ones for the foglights switchs....could be they are not quite home
by hormonedmonkey » Mon Jan 23, 2006 3:31 pm
so i should take panel off and make sure everythings snug!?
hormonedmonkey
by hormonedmonkey » Wed Jan 25, 2006 12:49 pm
fixed, it was a bit loose, but nothing i couldn't fix with masking tape! Yay for masking tape.
Cheers for help!
hormonedmonkey
by Doodley » Sun Jan 29, 2006 6:15 pm
careful of masking tape, it can catch fire if it gets too hot, try using insulation tape!
Doodley
