Throttle Position Sensor
by johnny_adidas » Thu Feb 09, 2006 4:30 pm
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->right i had a look on here <!--fontc--></span><!--/fontc--><a href="http://www.max-boost.co.uk/max-boost/Gotchas_LET.htm#TPS" target="_blank"><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->http://www.max-boost.co.uk/max-boost/Gotchas_LET.htm#TPS<!--fontc--></span><!--/fontc--></a><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--> cos everytime i touch the accelerator im getting a engine warning light on my dash and jerkiness as explained in another thread. <!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->[/size]<!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->getting way off readings when i checked with the multimeter compared to the readings on the max boost page. does anyone know if the same readings wud be expected from an xe rather than the let he's talkin about. and if they are does anyone know what the readings should be?<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->[size=2]in sayin that now there was a bit of grease on it and was hard to get a reading to be honest. could this be causing the problem? what would be the best wat to remove the greasey crud from the pins of the connector? carb cleaner do it?<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
johnny_adidas
by Robert_Dale » Thu Feb 09, 2006 5:26 pm
yeh carb clean it mate, failing that i have one at home i could send you!!
Robert_Dale
by johnny_adidas » Thu Feb 09, 2006 5:57 pm
cheers, ive just got a range of values that the multimeter should be getting and the fully open one is way out. gona give them a blast of the cleaner n see if it helps some bit. failing that i may take you up on that offer. thanks mate
johnny_adidas
by johnny_adidas » Tue Feb 14, 2006 5:01 pm
ok im onto the next few checks. inlet manifold gasket and a complete recheck of my airbox to throttle body ducting.
johnny_adidas
by johnny_adidas » Wed Feb 15, 2006 10:39 am
ive finally had to admit defeat and am waiting on a opel dealer to call me back with a price for cambelt change and diagnostic to find out what is causing the jerking. ecu light is now on constantly and getting less and less power every time i drive her. have checked all the intake from airbox to the throttle body and nothing seems amiss. hopefully they will be able to find the problem with the tech 1 and i might then be able to change it myself
johnny_adidas
by johnny_adidas » Wed Feb 15, 2006 11:17 am
oh sweet jesus!! 510euro plus the VAT for parts and labour on the timing belt kit, waterpump and drive belt. cudve seriously done without that.
thinking back on it i couldve sworn he just said 196 for the timing belt kit. dat sounds a hell of a lot
johnny_adidas
by johnny_adidas » Wed Feb 15, 2006 11:42 am
ok tink it may not be as bad as first thought. hopefully they will do the work if i can source the parts myself.
they said it wud take 2 hours labour. so say 510-[196(timing kit)+36(drive belt)+106(waterpump)] =172 {all exclusive of VAT}
so dats working out about 100 an hour labour. so if i get the parts myself. im working out about 80(timing kit)+0(already have drivebelt at home)+50(waterpump) so dat wud be 350 total say including fitting and even if i had to pay 40 for the tech 1 test then i wudnt mind. plus i reckon if im doin it that way ill just get the tech 1 done now and find out whats faulty and then order any extra parts i need from the same crowd online to reduce the postage.
johnny_adidas
by Naz » Wed Feb 15, 2006 6:58 pm
Why you not reading the codes yourself using the paper clip test?!!! have a look in the general tech regarding 'if your mgt light stays on'.
Naz
by Naz » Wed Feb 15, 2006 7:00 pm
Sorry its not in general tech, its in 'engine and gearbox'
Naz
by johnny_adidas » Thu Feb 16, 2006 10:23 am
not logging any fault codes. other than that id know where to start myself
johnny_adidas
by johnny_adidas » Fri Feb 17, 2006 11:13 am
shes going in to get tech 1 done today, hopefully it will shed more light on the situation. its after getting so bad now, i hate driving the car. wonder has a mouse crawled into my air intake? ah well, im sure the machine has a code for that as well [img]/wink.gif[/img]
johnny_adidas
by ealex » Fri Feb 17, 2006 12:05 pm
from what i know the throttle position sensor is the same on xe and let. better check codes though. anyway, paperclip test first. might not be what u think
ealex
by johnny_adidas » Fri Feb 17, 2006 12:19 pm
ok im kinda getting tired of saying this over and over!!!!!
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->not logging any fault codes. other than that id know where to start myself<!--QuoteEnd--></div><!--QuoteEEnd-->
johnny_adidas
by johnny_adidas » Fri Feb 17, 2006 12:23 pm
how about this everyone make a guess at what they diagnose the problem/s as!
only one guess each and ill give £1 to the winner!! hehehe
dodgy AFM is top of my list
johnny_adidas
by johnny_adidas » Fri Feb 17, 2006 7:59 pm
well its turned out to be the coolant temp sensor and the air floow meter so nothing too major really
guessing it makes way more sense to just buy new rather than trying to save a few bobs
johnny_adidas
