Window problem ?
Hi, ive just fitted Vauxhall remote central looking and have just found a problem. When locking the car with the remote the drivers window goes up but the passenger side stays down
I do know that since i bought the car you could`nt lock or unlock the passenger door with the key, could that cause the problem or something else.
Cheers Rob
Cheers Rob
Window problem ?
Robbie, check your connections in the passenger footwell. The brown/black wire is probably connected to the wrong wire or it isn't connected properly. I'm sure this would sort the problem. (it needs to be connected to the brown/black wire in the cars wiring harness)
skellem
<!--QuoteBegin-skellem+--><div class='quotetop'>(skellem)</div><div class='quotemain'><!--QuoteEBegin-->Well done mate!<!--QuoteEnd--></div><!--QuoteEEnd-->
And well done to you and all the guys for your help [img]/biggrin.gif[/img] where would i be with out this site
[img]/smile.gif[/img]
Users browsing this forum: No registered users and 58 guests
