Trip Computer vanished
by Duke » Thu Feb 16, 2006 9:57 pm
Hi Guys My Trip Computer Readout has just vanished, but it still lights up.
Why?
Maybe a Coincidence, but the oil light was on recently ( pressure is ok so i assume sender is shot ) now at the same time as the trip thing, the oil light has gone back out.
Is this Fairly Common?
Duke
by craigmcd82 » Fri Feb 17, 2006 10:15 am
Mine goes off occasionally too. Try giving it a smack, the ribbon cable from the computer to the display maybe loose. If that doesnt work, take it out and unscrew / unclip the face and make sure the wires are in place properly.
Think theres about 6 to 8 wires that look like a bunch of twist ties before you separate them.
craigmcd82
by icewizard » Fri Feb 17, 2006 10:39 am
Check your fuses, when I was messing about with the interier light I blew the fuse as it's on the same fuse.
icewizard
by Cozy » Fri Feb 17, 2006 10:51 am
<!--QuoteBegin-icewizard+--><div class='quotetop'>(icewizard)</div><div class='quotemain'><!--QuoteEBegin-->Check your fuses, when I was messing about with the interier light I blew the fuse as it's on the same fuse.<!--QuoteEnd--></div><!--QuoteEEnd-->
if you have blown the fuse it should show a little F in the bottom right corner of the trip computer display
Cozy
by Duke » Wed Feb 22, 2006 12:20 am
Ok so it was the fuse, lol
But it has blown twice again since, and the other day i had a totally flat battery, and the battery is ok, alternator kicking out ok.
Could something have drained it, but then how if the fuse was blown?
Or are these totally unconnected.
Lost now.
Fuse also has headlamp warning and reverse lights as you all know, but these seem ok.
Help.
Duke
by icewizard » Wed Feb 22, 2006 12:29 am
That fuse also does the check-control system too (All the warning lights left hand side of the dashboard. Collent level, brake pad wear, oil level, brake light detection etc).
What is very strange is that my trip computer has been showing the "F" all week and now it's gone and I've not changed anything????
Is that definitly what the F means?
icewizard
by Cozy » Wed Feb 22, 2006 9:44 am
<!--QuoteBegin-icewizard+--><div class='quotetop'>(icewizard)</div><div class='quotemain'><!--QuoteEBegin-->That fuse also does the check-control system too (All the warning lights left hand side of the dashboard. Collent level, brake pad wear, oil level, brake light detection etc).
Is that definitly what the F means?<!--QuoteEnd--></div><!--QuoteEEnd-->
yep deffo the fuse, i blew mine when i stuck an air compressor into the cig lighter socket
Cozy
