Sunroof Screws????
Sunroof Screws????
by BAD63R-V6 » Mon Mar 27, 2006 12:52 pm
Hi guys, right yesterday at the Clumber Park meet I asked if anyone knows why my sunroof still makes the normal opening sound but the roof doesn't actually open. Sofaman took one look at what reg my calli is anf then said he knew exactly what its. He popped the little circular cover next to interior light and found a brass screw in there. He then explained that i should remove the lining at screw it back it. To my horror I found another screw in the back of the roof and also couldn't find any holes for them to go in. Any ideas guys cuz this is driving me nuts:frown:
BAD63R-V6
by sofaman » Mon Mar 27, 2006 1:31 pm
Hi badger, the best I can do at the mo is this pic of the holes when the motor is removed. The brass holes are where the motor screws in. All 4 cables are ment to be straight. Hope this helps, if not I'll try and find some more pics. Ohh make sure you tighten all 4 screws and use thread lock unless you want to fix it again
sofa
sofaman
sunroof
by BAD63R-V6 » Mon Mar 27, 2006 1:50 pm
Right I've removed the motor and discovered exactly what is shown in that pic. What do i do now, send it to vauxhall:sob:
BAD63R-V6
by sofaman » Mon Mar 27, 2006 2:14 pm
straighten the cable and put it back together and see if it works.
Good luck
sofaman
by Animal » Mon Mar 27, 2006 5:06 pm
by sofaman » Mon Mar 27, 2006 9:33 pm
did you fix it mate ??
sofaman
by BAD63R-V6 » Wed Mar 29, 2006 12:09 pm
no luck i'm affraid, i can get it to almost shut and it wont lift high enough to open back fully
BAD63R-V6
by BAD63R-V6 » Wed Mar 29, 2006 12:10 pm
I think i need someone who knows what they are doing have a look cuz I can't get it back into postion.
BAD63R-V6
by sofaman » Wed Mar 29, 2006 1:39 pm
have you taken a pic of the rail thats poping out ?? Maybe someone can tell you if it's worth saving or not.
sofaman
by BAD63R-V6 » Wed Mar 29, 2006 6:10 pm
I managed to get he rail back in but it still wont go back into postion , i dont care if i never use it again i just want to get it shut properly
BAD63R-V6
by Animal » Wed Mar 29, 2006 6:24 pm
Is it not going into possision when it is closed?
by BAD63R-V6 » Wed Mar 29, 2006 9:23 pm
<!--QuoteBegin-Animal+--><div class='quotetop'>(Animal)</div><div class='quotemain'><!--QuoteEBegin-->Is it not going into possision when it is closed?<!--QuoteEnd--></div><!--QuoteEEnd-->
yeh, i tried taken the motor on and off a couple of times after i had made the cable straight and managed to get the roof to at least move if i need it to but it wont close properly. You can hear it closing so far and then makes a clunking sound as if something is jamming the roof open.
BAD63R-V6
by Animal » Thu Mar 30, 2006 12:10 am
Have u been pulling and pushing the cables to level the sunroof? Mine took a lot of pulling and pushing before I got it spot on.
by sofaman » Thu Mar 30, 2006 4:07 am
Try pushing the cables like animal said, if not I might have some free time the weekend if you want to pop over and I'll have a look at it for you.
sofaman
by BAD63R-V6 » Thu Mar 30, 2006 2:04 pm
I've had another look this morning, and no luck. I think i might take you up on that Sofa. Like i said before i reckon i need to have someone who's played with it before to have a look to see if it is savable. Let me know when is good Sofa.
BAD63R-V6
